правила![]() ![]() |
| telmaster |
Дата 4.12.2005 - 11:00
![]() Заглянувший Профиль Группа: Старт Сообщений: 7 Пользователь №: 825 На форуме с: 12.11.2005 Имеет предупреждений: (0%) ![]() |
| ELK |
Дата 4.12.2005 - 13:41
VW/AUDI/SEAT/SKODA Remote Control Programming (1997 ON) Procedure 1. Switch Ignition ON and leave the key in the ignition. 2. Mechanically lock the vehicle using the Drivers door using a second key. 3. Using the remote control press the Unlock button once, and the horn will sound once. 4. Wait 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed. NOTE : When performing programming on additional remotes the procedure is the same, except you press the unlock button 2, 3 or 4 times for the different remote. For example : If programming 2 remotes press the unlock button twice with a 1 second interval between each press, repeat for 3 and 4 remotes. 5. Switch Ignition OFF. 6. Remove key from ignition and check for operation. 7. The coding procedure can be repeated up to 4 times for additional remotes. 8. The ignition must be switched OFF between programming each remote control. Remote Control Erasing (1997 ON) Procedure 1. Switch Ignition ON and leave the key in the ignition. 2. Mechanically lock the vehicle using the Drivers door using a second key. 3. Press the remote control unlock button 5 times in 1 second intervals. A short horn will sound. 4. Wait 6 seconds and press the unlock button once to activate memory erase. 5. Switch ignition OFF, all remotes are now erased. |
| telmaster |
Дата 11.12.2005 - 19:36
| telmaster |
Дата 11.12.2005 - 19:38
Это сообщение отредактировал telmaster - 11.12.2005 - 19:40 |
